20 Most Recent Peg Perego John Deere Turf Tractor Questions & Answers
Turf
this is definitely in the wrong category
8/18/2017 4:11:45 PM • Peg Perego John... • Answered on Aug 18, 2017
John deere 175 hydro transmission very slow in
there is no transmission on these toys
8/18/2017 4:11:19 PM • Peg Perego John... • Answered on Aug 18, 2017
Info. for starter wireing hookup for model 3tn66uj
these toys do not have a starter
8/18/2017 4:05:44 PM • Peg Perego John... • Answered on Aug 18, 2017
Diagram 2003 4610 jd 4x4
this category is for the toy tractors
8/18/2017 4:05:19 PM • Peg Perego John... • Answered on Aug 18, 2017
How to troubleshoot a alltrax elc motor controler
i think you posted in the wrong category, this is for the toy tractors
8/18/2017 3:54:44 PM • Peg Perego John... • Answered on Aug 18, 2017
I have a John Deere L120A that the engine stays started but will bog down and not move
these toys don't have engines just electric motors
8/18/2017 3:53:56 PM • Peg Perego John... • Answered on Aug 18, 2017
No reverse in john deere ''gator''
check to see if both wheels are spinning in forward, if not you have a bad motor
8/17/2017 2:33:00 PM • Peg Perego John... • Answered on Aug 17, 2017
The tractor only runs in second gear
disconnect one of the motors and see if the problem is fixed, if it is then it is a bad motor
8/17/2017 2:26:54 PM • Peg Perego John... • Answered on Aug 17, 2017
Rear tires
pop off the center caps from both rear tires with a flat head screwdriver, and then remove the push nut washers by bending them with a pliers and removing them (keep in mind this will ruin the existing push nuts and replacements will need to be purchase from ebay or somewhere similar) then slide the tire off of the axle and replace (do not remove the axle cause there are spacers inside the vehicle that will fall out of place)
8/17/2017 2:21:45 PM • Peg Perego John... • Answered on Aug 17, 2017
The wire is disconnected in the pedal. Disassemble?
release the clips from underneath with a flat head screwdriver to release the gas pedal assembly
8/17/2017 2:16:31 PM • Peg Perego John... • Answered on Aug 17, 2017
Peg perego lawn tractor only one rear wheel turns at speed 2
sounds like a bad motor, swap the motors cables from left side to right and see if the problem follows if it doesn't then you need to replace the motor
8/16/2017 1:51:52 PM • Peg Perego John... • Answered on Aug 16, 2017
One rear tire not turning
sounds like a bad motor, swap the motor wires between the two sides and see if the problem persists if it does its the shifter switch, if it doesn't its the motor
8/15/2017 3:30:09 PM • Peg Perego John... • Answered on Aug 15, 2017
I bought a new battery & charged it for two weeks
check your charger with a multimeter and make sure its putting out at least 13.8 volts
8/15/2017 3:17:53 PM • Peg Perego John... • Answered on Aug 15, 2017
Battery is full on my sons peg perego john deere but it wont run
did you verify the battery voltage with a multimeter, could have a bad charger that gives a green light making one think that the battery is fully charged, also check the fuse on the battery
8/15/2017 3:15:17 PM • Peg Perego John... • Answered on Aug 15, 2017
Peg Perego won't go forward, only will work in reverse.
shifter swicth is probably disconnected
4/1/2015 10:08:11 PM • Peg Perego John... • Answered on Apr 01, 2015
Peg Perego John Deere Turf Tractor Logo
147 questions posted
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
need shifter stopper john deer tractor
  • Toys
