Most light domes twist on or off or have thumb screws to loosen and lower the dome.It sounds like you removed the light kit assembly instead of the dome.Try to put back by twisting in place the light kit assembly and look for screws,or hold back on trim and turn just glass dome do not use too much force .I checked web site but can't find your model.It is unusual to not be able to just remove glass dome.Look closely at how the glass dome is positioned. If no screws are visible either the glass part unscrews or the ring unscrews allowing glass dome to be removed.Good Luck.I have installed many ceiling fans the problem is if you didn't install it your at a disadvantage.GOOD LUCK.
