And you can't reset it a second time? If you bricked it, you should visit your phone store and ask them to do the reset. I hope you do make backups so now and then.
Hi there uninstall the key board driver from the laptop, then restart it again and install the driver from acer driver disk. Bbut before these please try the step below mentioned.
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
1. After press power button for turn on press F8 key.
If no luck after that all then you have to format your OS & installed it again.
When you get that message, pick the board up, press A and hopefully it will work for you. I had the very same problem, saw this solution online and it did the trick.
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide
to fix the problem yourself. This DIY guide will show step by step
pictures to fix the problems yourself without any technical knowledge.
You are getting this problem b'cause loss of ur system file i.e. "CONFIG.SYS", Which loads ur initial files and drivers needs to start ur operating System.
You must follow the steps given below to start repairing ur System:
1. Insert the Bootable OS Disk into ur CD/DVD-ROM.
2 Reboot ur System.
3. The system will prompt You to "Press any key to boot from CD".
4. Press Any key.
5. Now the system will load all initial files and hardware driver.
6. After loading driver and files, OS will ask you for acceptence with their Terms and Conditions.
7. You must Agree with terms and condition. press F8 key for accepting terms n conditions.
8. After step 7, OS will search for the partition of ur Previously installed OS. If you have two operating system then it will show two Partitions with their name and drive letters. (You must remember the drive letter where ur OS is installed that u want to repair)
9. Now Leave that option as it is. And press Escape key.
10. Now You'll be able to see all those partitions you have on ur Hard disk, with their drive letter, Name and free space.
11. Select the partition of OS that u wanted to Repair, By Scrolling Arrow Keys. (Be carefull while selecting the Partition. If you select wrong partition then You wont be able to repair ur OS)
12. And then Press "R" Key from ur Keyboard.
13. Now OS Will search for the partition you have specified.
14 It will Delete Old system files and Copy New files (Note: You won't loose any data, Previously you had saved on ur boot partition).
15. After Step 14, OS will save the configuration and Will Reboot itself.
16. Again You will be asked for "press any key to boot from CD".Don't Press Any key at this step.
17. Now follow the wizard n specify correct information you will be asked.
18. It will take about 20 to 30 minutes to Repair ur OS.
Note: These Steps are not valid if you are using Windows Vista
