Smartlock code
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
Philips sets use a four digit code to control the v-chip. The override code
for Philip sets is 0711, although it may say "Incorrect code" the first time
to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To
use it hit the MENU key to get to the menus. Go up or down until you reach
AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow"
key on the remote. Enter the override code, and enter it a second time if it
says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right
arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to
MASTER DISABLE and press the "right arrow" key so that it says "MASTER
DISABLE ON". The v-chip is now reset.
mine stays on channel 3
my channels are locked
tv is saying locked channel by tv-7 and tv-14
channel blocked
channels blocked by tv-y. how do i unlock channels so direct tv will play?
Absolutely insane!!!! Even TV-G is locked!!!! Remote is junk
