20 Most Recent Emerson SpongeBob SquarePants TV Questions & Answers
3answers
Universal remote code for spongebob tv
I doubt you will find any that work---no one so far has--Google for a replacement remote other than the universal.
5/21/2023 12:51:08 PM • Emerson... • Answered on May 21, 2023
Sometimes the sound doesn't work but on other channels it works fine
Change sound settings.
9/12/2017 12:49:37 PM • Emerson... • Answered on Sep 12, 2017
I have bouth tv and dvd player is there some way to run the tv off the dvd remote
sure there is get a universl for both TV and DVD https://www.google.ca/aclk?sa=L&ai=C63-bxM3LVvTOLoaFpgOY2rfoA5Hx8PoDoeTZlbYCutvrRAgAEAFg_bCYgegDyAEBqgQoT9AmfEo9Wwb0dMBEeFvVZ38ZiamAeZlmF5wVQF_SEtz5-dMpA4M7CYAHyZixLZAHAagHpr4b2AcB&sig=AOD64_2pMpwzQVAcf_lhlQDrPfUsMqo9cQ&clui=0&q=&ved=0ahUKEwib7Zvk9IzLAhVqnIMKHQfdBzEQ0QwIGQ&adurl=http://www.amazon.ca/s/%3Fie%3DUTF8%26keywords%3Dtv%2Buniversal%2Bremote%2Bcontrols%26tag%3Dgoogcana-20%26index%3Daps%26hvadid%3D83217279401%26hvpos%3D1t1%26hvexid%3D%26hvnetw%3Dg%26hvrand%3D5452421428183093128%26hvpone%3D%26hvptwo%3D%26hvqmt%3Db%26hvdev%3Dc%26ref%3Dpd_sl_6ymem9rjmt_b https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwib7Zvk9IzLAhVqnIMKHQfdBzEQFgglMAA&url=http%3A%2F%2Fwww.dx.com%2Fc%2Fconsumer-electronics-199%2Fremote-controllers-1009&usg=AFQjCNFp5llC054BRS9We5v552Y2Lo5Lug&bvm=bv.114733917,d.amc https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwib7Zvk9IzLAhVqnIMKHQfdBzEQFggxMAI&url=http%3A%2F%2Fwww.walmart.com%2Fbrowse%2Felectronics%2Fremote-controls%2F3944_1060825_133270_4538&usg=AFQjCNE7GWED7Yt3c6roQqJ_C_x5fGd1GA&bvm=bv.114733917,d.amc https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0ahUKEwib7Zvk9IzLAhVqnIMKHQfdBzEQFghSMAo&url=http%3A%2F%2Fwww.oneforall.com%2Fremotes.html&usg=AFQjCNEROZnQsQ1rbXyWiq53SPFh3lI9dg&bvm=bv.114733917,d.amc https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=14&cad=rja&uact=8&ved=0ahUKEwib7Zvk9IzLAhVqnIMKHQfdBzEQFghjMA0&url=http%3A%2F%2Fwww.ebay.com%2Fbhp%2Fsylvania-tv-dvd-remote&usg=AFQjCNF0kJwvaRxYzkx4DbJv4je_eAtIjA&bvm=bv.114733917,d.amc
2/23/2016 3:12:34 AM • Emerson... • Answered on Feb 23, 2016
2answers
No sound
There are only two easy possible reasons:
1) IF it has a earphone jack of some kind it may be damaged or bad.
2) Place your ear to the speaker and turn the sound all the way up to see if you hear anything.
If not a problem with a earphone jack or a bad speaker it will not be economical to repair---for this size set better to just replace it.
SD TECH
1/13/2015 7:25:53 PM • Emerson... • Answered on Jan 13, 2015
2answers
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
9/24/2014 11:54:27 AM • Emerson... • Answered on Sep 24, 2014
How do i make sure that my microphone and earphone jacks are turned on in my HP Pavilion dv2025nr
In the system settings under audio, you'll see the settings and test screens for these.
6/21/2014 8:30:49 AM • Emerson... • Answered on Jun 21, 2014
How can i replace the speaker for a spongeboy 13 tv?
To replace it you have to open the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular brand TVs are given with illustrations.
5/23/2014 3:21:14 AM • Emerson... • Answered on May 23, 2014
0answers
0answers
Brand code remote
Be the first to answer 3/17/2014 4:03:40 AM • Emerson... • Posted on Mar 17, 2014Be the first to answer
0answers
Hook vcr to T.V
Be the first to answer 1/26/2014 4:04:15 AM • Emerson... • Posted on Jan 26, 2014Be the first to answer
Television has no sound
Check its speaker.
3/2/2013 5:05:18 PM • Emerson... • Answered on Mar 02, 2013
Tv has no sound
Check its speaker first. If it is checked OK, check and replace damaged component/s at the audio output section circuit.
3/2/2013 2:37:17 AM • Emerson... • Answered on Mar 02, 2013
I need to put my tv on video for games
You are going to need the original remote unless the set has a input, TV/video, or source button on the front or side.
12/7/2012 8:19:52 PM • Emerson... • Answered on Dec 07, 2012
I want to turn on video for playing games and lost the remote.
Hard with the Emerson name to say who actually made this set but they have a long history of using oddball codes so you may be stuck with searching for the original remote, and I would expect a Universal will not program to work on this unit.you might consider Google or Even EBAY for the right remote.
12/7/2012 1:22:35 PM • Emerson... • Answered on Dec 07, 2012
13" EMERSON TV WON'T TURN ON?
What can anyone advice what to do with a dead set? Contact any experienced service technician.
12/5/2012 2:48:56 PM • Emerson... • Answered on Dec 05, 2012
Emerson SpongeBob SquarePants TV Logo
185 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
way switch video without
  • Televison & Video
