SOURCE: kawasaki zzr400 (1994 model),streetfighter wont start
Its Starter relay may be causing main problem. You can try Yezdis starter relay as it can help you solving your problem
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
SOURCE: Starting and once started won't run
The problem seem to involve a number of circuits, I would suspect the Key switch as it supplies power to all affected systems. The dieing on release of the clutch is usually the kickstand safety switch. If the kick stand is not up, and the bike in gear, then when the clutch switch detects release is kills the engine so you don't kill your self.
Check or replace these switches.
Hope this is of some help.
Ed
SOURCE: kawasaki mule heat light staying on
Replace the impeller in your water pump. It's an easy job and needs to be done every 2 or 3 years depending on use. Why they put a rubber impeller in these I do not know. Your local Kawasaki dealer will be able to help you with the part.
SOURCE: '04 Kawasaki KFX 700 idle problems from hard throttle to idle
1. Did you clog your airfilter with gas or anything else when you rolled it?
2. Did you damage the petcock or fuel control?
3. Choke cable stuck open?
