20 Most Recent kawasaki Full Suspension Mountain Bike Men Questions & Answers
I hooked up my battery backwards and now that I re dis it right it wont start
kawasaki Full... | Answered on Dec 01, 2018
can you show me a video on the cam timing on a 1980 kz 440 please
kawasaki Full... | Answered on Jul 29, 2018
of course , idea is the carb float is stuck open .
kawasaki Full... | Answered on May 11, 2018
Most of the time you can look up the owners manual on websites as long as you can find the kawasaki website you should be good, i had the same problem with a dirt bitke and i found there website and found the owners manual and downloaded the owners manual and printed it out. Hope i was of some help to you.
kawasaki Full... | Answered on Apr 29, 2018
Replace it. Get a floor model at lower cost
kawasaki Full... | Answered on Jan 14, 2018
If it didn't pop after the valve adjustment, try adjusting the valves again.
Popping out the exhaust usually indicates a burned exhaust valve. The valve doesn't seat all the way around and air/fuel mixture is getting into the exhaust header on the compression stroke and igniting from header heat. The reason this doesn't happen at higher rpms is the amount of time for the air/fuel to leak it really short.
kawasaki Full... | Answered on Dec 11, 2017
Could be dirt in a fuel jet in the carb. You cap purchase a fuel cleaner to put in the gas tank and if that does not work the carb will have to be cleaned.
kawasaki Full... | Answered on Nov 04, 2017
try a new plug sometimes a plug will not fire under compression. also adj the valves
kawasaki Full... | Answered on Oct 25, 2017
have you checked /tested the kill switch
kawasaki Full... | Answered on Aug 28, 2017
cant help you with your issues but do you know they can void your warranty for modding it?? especially now since your dealer is involved. have you pulled the plugs to see if one is damaged yet? im assuming this is a 2 stroker right?
kawasaki Full... | Answered on Jul 27, 2017
p[robably neither but a broken return spring on the selector lever
kawasaki Full... | Answered on May 15, 2017
Replace the glow plugs one or more are shorted
kawasaki Full... | Answered on Mar 15, 2017
kawasaki Full Suspension Mountain Bike Men Logo
432 questions posted
Top kawasaki Sport & Outdoor - Others Experts
Steve Worthey
Level 1 Expert
Wayne McNeil
Marvin
Marvin
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • kawasaki Sport & Outdoor - Others
Most Popular Question
kawaski 440
  • Sport & Outdoor - Others
