SOURCE: Braun Tassimo Coffee
It's most probably from the overflow which is situated behind the splashback. When the machine leaks from there it generally means that it needs to be descaled. You can use a general descaling agent powder. dissolve it into the water container filled to max, with the cleaning disc run a few cycles with 15 minute gaps between each cycle. after it should be fine.
SOURCE: lights keep flashing on my tassimo machine
I know that if the water reservoir is empty or the reservoir isn't properly attached all the lights flash until I correct it. I think the first time I powered on my unit all the lights flashed as well but went away after I put a coffee disc in.
if your lights are flashing on your mashine just keep your finger on the button untill its filter threw, willtake up to 2 mins. simon bernasconi
