20 Most Recent
Braun Tassimo TA1200 Espresso Machine Questions & Answers
All the lights are flashing on my Braun Tassimo
Several possibilities:
(1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
When I turn on my Tassimo Coffee maker, the refill
I ran into the same problem myself. One possibility is this: Follow this sequence: 1) With the top up and the disk NOT engaged, turn the main power on. 2) Put the disk in and lock the top down. At this time, the cup logo shouls flash once and stay on. 3) Push the large round button once and the cup logo will flash and the brewing should start.I had a few things out of sequence at first and it was frustrating me as well. I hope this helps!!
