Hello
Chunchop remote has no setup codes with Olivia TV. Just buy one RCA RCR312W remote control. It has codes for Olivia, and most of the other TVs at present. You will get its maual with codes and proceedings about how to setup and synchronise it with your Olivia Tv.
The codes for Olivia with this remote control are:
11610, 11144, 11240, 11331
OK.
Here's a link to the manual (I always toss them, too)!
http://us.sanyo.com/dynamic/product/Downloads/DP50749%20OM%20(332--)-45914968.pdf
Hope this helps!
Rate my solution!
Ask Manualfox.com - it is a personal Document Search Service
for electronic user, service manuals and drivers. They help you to save
time and money by finding your needed product information.
List of Codes: http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMEZ4
To program a code simply do the following steps:
Press SET more than two seconds. The SET indicator lights up.
Press the button of the component that you want to set up. The SET indicator lights up.
Press the Number buttons to enter the four-digit component code number.
Press ENT. The SET indicator turns off. If the SET indicator flashes five times before lighting up, it means that the setup is incomplete. Confirm the component code number and start over from Step 3.
If the code setting is not finished properly If you do not input anything into the Commander within 20 seconds between each step, or if you press SET while setting the component code, the setup procedure will be canceled. Start over from Step 1.
(To read / download the manual yourself go to: http://www.docs.sony.com/release/RMEZ4.pdf)
