Furuno GP31 GPS Receiver Logo
Posted on Jul 03, 2008
Display position on PC
Goodday to all,
My name is Michel Fosouo, I have connect a gps furuno GP 32(according to operator's manual) to my computer but but I dont have s6ftware which should be ran to display the input data (position) from GPS to LAbtop computer .
Please help me.
Thanks in advance.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Sep 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4164
Points
6
Hi miguel09,
You could try SeaClear It's free and runs not only on Windows systems but also on Linux with Wine. If you want to upload routes and waypoints then you can use this software from Furuno.
Best Regards
Lars Erting
1helpful
Furuno GP31 Navigator. How do I can change language from German to English please?
Question edited for clarity.
Page 75 of the manual refers
https://www.manualslib.com/manual/1183586/Furuno-Gp-39.html?page=75
Menu - System - Language
Menu (the U with two dots over it Umlaut) - System - Sprache
Mar 31, 2023 • Furuno GPS
Furuno GP-1800 GPS/Plotter switches on, display has only lights otherwise blank.
Try pressing the Brill or Tone key. Use the up arrow to increase Brill and the right arrow to increase Tone. Otherwise, you have an internal board failure and it will require service by tech.
Have just taken possesion of boat with furuno GP 32 and would like some sort of instuction manual
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
2helpful
LOOKING FOR OPERATORS MANUAL FOR FURUNO GPS NAVIGATOR GP-70 MARK 2
You'll find one on the Furuno site - follow the link
http://www.furunousa.com/products/productdetail.aspx?product=GP70MK2&category=Products+%3a+Previous+Products+%3a+GPS+%26+Chart+Plotters+%3a+GPS+Receivers
It's an ominous date to be looking for a manual! Has it stopped working or is it just the date that's wrong?
12 Dec 2010 is 'GPS week number rollover' for the GP-70 Mark 2. See www.furuno.co.jp/en/pdf/080531_notice_en.pdf for details.
I
Dec 12, 2010 • GPS
2helpful
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Screen on GP 32 is washed out. Where can I get a new display
Contact your local Furuno dealer. That system uses the popular RD-30 display unit and should be rather avalible.
Manual
http://www.mapsunique.com/ev/special-inst/furuno-30.htm
Here is a site that knows something about it. and to find where to buy one google it.
2answers
Upload waypoints via laptop
Quite honestly, this is not worth the trouble. It easier to re-enter the waypoints manually. If you want to try it, you need to get some GPS connection software from someone like: http://www.gpsu.co.uk/. You cannot do it with your PC and cable alone. Good luck.
Gps
Hi fire1961,
Downloading data from my FURUNO GP-30 gave me no problems. But it took me long time to figure out why I coudn't upload waypoints and routes to the GP-30 via the serial port in my ThinkPad T30.
I tried nearly everything tested the cable, tested a lot of different software and even wrote a little c-program to communicate with the serial port. I also tried a serial-to-usb converter with no results. Then I stumbled over this RS232 Tutorial. According to this - serial ports are not just serial port but can be divided into three general categories:
The types of driver ICs used in serial ports can be divided into three general categories:
* Drivers which require plus (+) and minus (-) voltage power supplies such as the 1488 series of interface integrated circuits. (Most desktop and tower PCs use this type of driver.)
* Low power drivers which require one +5 volt power supply. This type of driver has an internal charge pump for voltage conversion. (Many industrial microprocessor controls use this type of driver.)
* Low voltage (3.3 v) and low power drivers which meet the EIA-562 Standard. (Used on notebooks and laptops.)
Then I installed the waypoint upload software to my ten years old Compaq Presario and suddenly I could upload routes and waypoints but only via the on board serial port. The serial-to-usb converter didn't still work.
So if people experience no result trying to upload data to these old GP-30's from their notebooks and laptops. Then I think it could be a matter of these Low voltage ports not are able to provide the FURUNO device with enough voltage. See the above RS232 Tutorial.
Best Regards
Lars Erting
1helpful
2answers
Can't Receiver ( No Signal )
if it has no signal , measure the antenna output with avo meter. you must see approximately + - 5V. if it is ok.. seems that antenna problem.
furuno technician Ozgur CALIK
Top Furuno GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Furuno GPS Expert? Answer questions, earn points and help others
