http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf The GP30/GP31/GP32/GP35 are all similar.
Is this a request for a GP31 Manual? I have posted http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf which is basically the same beast.
I have posted the Operator Manual at http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf
Use this to check out section 7-10 to make up a cable to connect to a PC to allow download of data. Then, using the manual as a reference figure out the sequence of buttons to press to get the GP31 to download the waypoint and route data to the PC. Just press the buttons and assume the display is showing the next prompt. If you know someone you has a working GP31 get them to do the sequence and write down the buttons they press. You just copy the same sequence. You will need some software on the PC to capture the data,
According to your problem, first reset the GPS device. Reset the antenna. Make sure your position that the antenna can receive the network. So set the position properly. You may need a firmware update for the device. If it doesn't solve your problem then you can reload the software of the device. You may have to replace the antenna. But before that, check the connection of the antenna properly.
56 questions posted
31 Questions
32 Questions
39 Questions
15 Questions
10 Questions
