20 Most Recent Furuno 1715 LCD Radar System GPS Receiver Questions & Answers
3answers
Furuno 1621 radar will not power up
With a voltmeter, verify that you are getting 12V at the plug end of the power cable. If so, check the fuses (there should be one or two fuse holders on the back). If all of that fails you will need to send it in to Furuno for repair.
4/8/2017 6:07:19 AM • Furuno 1715 LCD... • Answered on Apr 08, 2017
Furuno radar 1715
Cek wiring to scanner, change reedswice sensor /heading sensor. If the problem not solve, change the display with the new one.
10/18/2016 4:13:04 AM • Furuno 1715 LCD... • Answered on Oct 18, 2016
Target not found,
change maghnetron.
11/18/2015 2:49:50 PM • Furuno 1715 LCD... • Answered on Nov 18, 2015
Repair radar india
hey guyyou have to change mic .you will solve the problemkk
11/18/2015 2:43:02 PM • Furuno 1715 LCD... • Answered on Nov 18, 2015
How do i trouble shoot my radar
Trace power wire from unit to find in-line fuse. check fuse. If OK continue to battery or power panel using 12 v dc meter. must have long ground wire to battery ground(-) to meter(-)
12/25/2014 2:35:17 PM • Furuno 1715 LCD... • Answered on Dec 25, 2014
2answers
Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
10/23/2014 2:38:38 PM • Furuno 1715 LCD... • Answered on Oct 23, 2014
2answers
I have a Furuno 1622 radar. It only shows a ring
I don't beleive this is goning to fix your problem. Open the dome and visually check that it is spinning. There is a maintenance menu though. To open the maintenance menu;
1. Turn the radar on.
2. Wait until the initial screen appears, then press and hold UP and DOWN keys together.
3. In about 10 seconds, the maintenance menu as shown below will appear.
4. Press MENU key to close the menu.
6/25/2012 8:08:12 AM • Furuno 1715 LCD... • Answered on Jun 25, 2012
1. What is the average
The life span of the radar depends on its use.There are consumables inside, mainly the Magnetron and the scanner motor assembly, the life of which depend on running hours. The life of Display is high compared to these two. The TR cell is located in the wave path before the receiver(detector/MIC)Most Radars have a menu function for 'Test".
12/6/2011 5:03:38 PM • Furuno 1715 LCD... • Answered on Dec 06, 2011
How to reset furuno 1715
By 'reset' I guess you want to clear the contents.This is how you do.Turn on while pressing [menu/escape].You get installation menu.Move down to 'memory clear' and press [right arrow]Select 'yes' to clear.Memory will be cleared when switched on next time.Hope this helps.
12/6/2011 4:49:32 PM • Furuno 1715 LCD... • Answered on Dec 06, 2011
2answers
RE: life of the radar magnetron
i have a furuno 1700 radar ,when i switch it on it goes to stand by ,when i press the standby button you can see it scanning but no land appears cheers alan
5/3/2011 3:11:30 PM • Furuno 1715 LCD... • Answered on May 03, 2011
How can I get an owners manual
4/3/2011 11:40:01 PM • Furuno 1715 LCD... • Answered on Apr 03, 2011
We have a radar Furuno 1622 - the scanner scans
I know this question is very basic, but did you check your gain and clutter settings? That echoes show in short range, disappear, reappear, and are not consistent on long range sounds normal to me. Auto settings sometimes also can get a bit mad, then manula settings makes sense.
Did you run the unit and scanner test?
1/13/2011 12:29:44 AM • Furuno 1715 LCD... • Answered on Jan 13, 2011
Furuno GaAs FET Front End
unplug the radar from it and turn on the display. If that does not blow the fuse, then your problem is either in the cable to the antenna or the antenna itself. Start there.
1/7/2011 4:41:46 PM • Furuno 1715 LCD... • Answered on Jan 07, 2011
Hi, I just bought an
Always happy to help someone that WANTS to use the manuals, many people don't.
http://www.furunousa.com/products/productdetail.aspx?product=1715&category=Products+:+Radars+:+Radars
11/26/2010 10:11:29 PM • Furuno 1715 LCD... • Answered on Nov 26, 2010
Radar Furuno 1715 . Problem
mic assembly
11/24/2010 5:06:46 PM • Furuno 1715 LCD... • Answered on Nov 24, 2010
Furuno 1715 LCD Radar System GPS Receiver Logo
41 questions posted
Top Furuno GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Furuno GPS Expert? Answer questions, earn points and help others
View Most Popular
Furuno GPS
  • Furuno GPS
Most Popular Question
re life radar magnetron
  • GPS
