JAKKS Pacific EyeClops® Mini Projector Logo
Posted on Dec 18, 2010
Jakks Pacific Eyeclops mini projector worked once for about an hour; was using AC adaptor not batteries; however upon second use, the project will not power up-no sound or light, any ideas on what is wrong with it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
382
Points
Buy another mini projector- go to the store from where you got it, exchange it for another or get your money back
What chargers work with Spynet watch besides on what it came with?
If your watch has micro usb socket that regular micro USB cable and phone charger will work
What other chargers for Spynet watch that work?
All you need is a mini-USB to USB cable. Then use your laptop or any open USB port to charge.
I think that the led light burned out
You do know the lamp won't light unless the projector has an input source connected?
It's not designed to be repaired because there are safety issues in case you put too bright a lamp in, after all it is a children's toy. That said you have 2 options, take out the old lamp, and identify it, that should be fairly easy, or contact the distributors.
Contact JAKKS
1helpful
Vox mini led projector light blinking problem
I dont think it as solution. when power on, it has to show the VOX logo initially. Later we can set the i/p mode...
I had the problem with my new led vox projector. Larer I replaced it. now I got the same issue with the replaced product. Each time I used only 2 to 3 hrs the device. Waste of buying such brands.
2helpful
2answers
Jakks spytech watch only will work when connected to USB port of computer. If disconnected it goes blank and will not operate. When connected toi USB port the following message is the only thing...
Same problem. But I am able to set the location, time and date while usb connected. As soon as I pull it out, total failure. Even tried the RESET button on back, but nothing works.
Anybody... anybody?
My son got a Spynet Video Watch for Christmas. He has been charging it for over 5 hours and it still doesn't show a full charge. It only shows half a charge and when he takes it off and tries to use it...
Hello, Pdschanz -
Since the watch was a Christmas gift, it is probably still under warranty.
I hope you found and downloaded the instructions for the watch, saved them in a Documents file with a file name you can find again easily, printed the instructions, and read them thoroughly all the way.
If you have not yet contacted Customer Service for the watch, I suggest you do that after reading through the instructions and the FAQs near the end of the instructions.
This is the telephone number for Customer Service for Jakks Pacific Inc., manufacturer of the watch:
877-875-2557
Malibu, California
Call weekdays during normal office hours, Pacific Time zone.
This is the email address for Jakks Pacific Customer Service:
[email protected]
Source of information:
Instructions for Spynet Video Watch with Night Vision
http://www.spynethq.com/core/pdfs/instructions/Video_Watch_with_Night_Vision.pdf
Best wishes.
3helpful
Can i connect the eyeclops to a laptop?
Yes you can. If you have composite video out. Composite video is the Yellow connector like you see on TV's, DVD's, VCR's, and other items. It uses a standard RCA connector.
If your laptop doesn't have a composite out you can purchase an adapter that will supply this. These adapters are usually connect to your USB port.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/bruce_8f867df5c2afe8cb
3helpful
2answers
Problem with eyeclops video projector...after
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
Top JAKKS Pacific Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
