20 Most Recent
JAKKS Pacific Eyeclops Bionic Eye Tv Plug-in Microscope Questions & Answers
Vox mini led projector light blinking problem
I dont think it as solution. when power on, it has to show the VOX logo initially. Later we can set the i/p mode...I had the problem with my new led vox projector. Larer I replaced it. now I got the same issue with the replaced product. Each time I used only 2 to 3 hrs the device. Waste of buying such brands.
Problem with eyeclops video projector...after
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
Can i connect the eyeclops to a laptop?
Yes you can. If you have composite video out. Composite video is the Yellow connector like you see on TV's, DVD's, VCR's, and other items. It uses a standard RCA connector.
If your laptop doesn't have a composite out you can purchase an adapter that will supply this. These adapters are usually connect to your USB port. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/bruce_8f867df5c2afe8cb
Our mini eye clops projector
Usually wnen this occurs, it's either because of low voltage in the power supply, or it could be a faulty component. Make sure the battery pack is fully charged (measure it with a voltmeter). The voltage rating will be on the cord plug-in for the charger, or in the manual.
Aside from checking the batteries, the unit will have to be opened up and troubleshot.
I'm not sure what their support might offer, so you should contact them if the battery pack checks out ok, but the unit is still failing. Here's their support site:
http://www.jakks.com/privacy-policy
Good luck, and hope this helps.
VJ starz video karaoke machine
The truth is that the user manual/instruction for your VJ starz video karaoke machine
is not available anywhere online.
The manufacturers of this unit did not make it available. I went
further searching and couldn't find any.
I would suggest you
contact the manufacturer of this unit via phone or e-mail and
request for the instruction/user manual from them. They might give it to you or direct
you to a dealer where you can get the instruction/user manual.
This is the best you can do to get the instruction/user manual you are requesting for.
Go to the VJ starz video karaoke machine website, check "Contact Us" and you would see
their e-mail and phone number.
Good luck.
Scanopedia won't turn on (at
I guess you mean that scanopedia Discovery Channel. i would recommend you contact your cable provider.. they may get you started.
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
