Televison & Video Logo
Posted on Jul 02, 2008
Sky remote codes
Does anyone know sky remote code for Technika TV. Just bought one for bedroom and can't operate volume etc. Any help??? Technika doesn't appear on list of sky / tv codes.
thanks
Kim
  • 3 more comments
  • Anonymous Mar 16, 2014
    Hi i need a list of codes for a Teac set top box hdb850 please have bought a 2 in 1 remote tv works well but set top box does not.
    I have been using my Sky remote for both tv and sky to use telly. I am now getting a message sayuing No channels have been added yet. What could be the problem?
  • Anonymous Mar 18, 2014
    sky remote will not work need code
  • Anonymous Mar 20, 2014
    require remote code for sky volume
  • Anonymous Mar 31, 2014
    4 digit code
A
Anonymous
4answers
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
5helpful
3answers
Could you tell me sky remote code for technika model 22-220
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says REV 4, REV 6, or REV it might work with one of these codes:
1177 or 2011
However, according to Sky you need the VERY latest Sky remote to control the Technika 22-220.
Personally, I thought REV 8 was the latest version, but it seems they have a newer one. I can't find any reference to it or anyone selling it though - even Sky themselves.
Try the 2 codes above and report back.
2helpful
2answers
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
14helpful
3answers
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
2answers
Sky remote not controlling volume
press tv on the sky remote
press and hold select and red until the LED blinks twice
enter the code
press select
it should work if you have the correct code
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
23helpful
8answers
Need code for technika tv
i have bought a one for all tv controller and it doesn't have the code for a technika tv
2answers
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
1helpful
9answers
Sky+remote code for my lg tv
The cose you need is 0206
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
