HI there
I would imagine the drivers from M-Audio are not signed and therefore may not be proven to be compatible with win7. I checked the website and they have drivers for different service pack levels on Vista (I know yours is win7) which is very unusual. This points to them having issues releasing signed off working drivers. Make sure you know what you have installed, 32 or 64 bit win 7. Do not go by the sticker on the case. Go start>control panel>system and look it up
Both versions of 64 bit and 32 bit seem the same file
FireWire_6.0.1_5.10.0.5058.exe
which seems weird too
I would uninstall the drivers and choose delete as well
start>search> type 'dev' and see the results. Click on device manager, open it
under sound right click all devices>properties>click on driver tab>
then click uninstall but tick the delete driver box too
then reboot the pc but do not load the driver from M audio
we want Microsofts generic driver to load
After the reboot see if it works.
If not do a system update (start>search>type 'windows u' and click on windows update
Look under optiopnal updates and see if there is one for an audio device and load that
Failing this try the M audio XP driver
If that fails, uninstall and delete as per earlier.
Failing that try the Win 7 driver for 32 bit
Failing that try the Win 7 driver for 64 bit
I think M audio has issues with code for drivers and win 7
http://www.youtube.com/watch?v=anJJ02VV1qs
You may want to look at a new system as it seems M has some bad press with support.
All the best now, but it may be that the drivers are not signed off from Microsoft. If this is the case, you may want to chase up M audio and ask if they can be honest and let you know if there are any issues with Windows 7.
Microsoft are releasing Service Pack for Win 7 first half of 2011 and this may mop-up some issues.
http://windows.microsoft.com/en-GB/windows/downloads/service-packs
Phil
