20 Most Recent M-Audio Keystation 49E 49-Key Entry-Level USB MIDI Controller with Session Recording Sof Questions & Answers
It sounds like a hardware issue, you will need to get your keyboard repaired
M-Audio... | Answered on Nov 26, 2017
who cares its just a millisecond and its just takes a while for it to load on the computer nobody actually counts the time it takes
M-Audio... | Answered on Dec 07, 2009
JA user_offline.gif vbmenu_register("postmenu_31136", true); M-Audio Tech Support Join Date: Jun 2008 Location: Irwindale, CA Posts: 5,033 icon1.gif "I asked our repairs department and they said the problem is either the main board or the velocity board. You can order both boards from our repairs department and return the one that is not needed. The main board goes for $20 and the velocity board for $14. 626-610-2529, Mon - Fri, 9am - 5pm Pacific Time."
I just found this in the M-Audio forums. I've just called the number and left a message at M-Audio requesting a callback. I'm really hoping that tech support will have a solution for whatever is causing this malfuntion. . . I'll post here again when the parts come.
M-Audio... | Answered on Apr 28, 2009
Measure it myself from original card and cable.
M-Audio Audiophile 192 Pinout
DB25 Male, front view:
01 02 03 04 05 06 07 08 09 10 11 12 13
14 15 16 17 18 19 20 21 22 23 24 25
In and Monitor cables are connected to same pins (so are interchangable):
22 In L Gnd - Monitor L Gnd: iLg
21 In L Tip - Monitor L Tip: iL+
09 In L Med - Monitor L Med: iL-
08 In R Gnd - Monitor R Gnd: iRg
07 In R Tip - Monitor R Tip: iR+
20 In R Med - Monitor R Med: iR-
Main OUT:
19 Out L Gnd: oLg
18 Out L Tip: oL+
06 Out L Med: oL-
05 Out R Gnd: oRg
04 Out R Tip: oR+
17 Out R Med: oR-
Midi (Female connectors):
11 Midi Out 4 mO+
12 Midi Out 2 mOg
24 Midi Out 5 mO-
13 Midi In 4 mI+
25 Midi In 5 mI-
Midi In specifications leave Gnd pin 2 unconnected.
So connector its:
01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+
14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
M-Audio... | Answered on May 06, 2019
Have a read at this article. I assume you are using ASIO4ALL if not then you should.
http://www.image-line.com/support/FLHelp/html/recording_audio_USBmic.htm
Specifically this part:
Note about latency: USB microphones generally only allow you to hear the sound being recorded after it has passed through FL Studio. As the latency of USB microphones depends on the ASIO4ALL latency settings, there may be a troublesome delay between the sound made and it being reproduced from your speakers or headphones. For example, low latency monitoring is particularly important to vocalists as high latencies cause a distracting echo effect. The only solution to this problem is to lower your buffer length settings (there are limits) or obtain a new soundcard with direct-monitoring.
M-Audio... | Answered on Feb 24, 2015
Be careful and take off the side panel to the PC tower to expose the inner parts of the computer and there you find that your sound card is inside attached to the motherboard (The Mainboard) get a star or flat head screwdriver and unscrew the screw, slowly put out your sound card (Don't forget to unplug your audio wires first) then what I do is get a Q-tip and dab it in some alcohol then just roll it on the paint leg or napkin and wipe off the little gold tips were the card slides in from BOTH SIDES and also check to see if there is a lot of dust inside your PC its pretty good that you blow it out that way it doesn't overheat as well now just put the card back in and see if that works and if not then you most likely need a driver for it and for that go to the website of the soundcard and go to support and drivers for your sound card version...Hope this helped thanks
M-Audio... | Answered on Jan 01, 2015
Well thevskipping part is the quality of your player, and the sound is often when somebody doesn't know how to convert stuff.
M-Audio... | Answered on Sep 16, 2014
Balance is adjusted with the mixer on your computer. So is the volume.
M-Audio... | Answered on May 07, 2014
M-Audio Keystation 49E 49-Key Entry-Level USB MIDI Controller with Session Recording Sof Logo
16 questions posted
Top M-Audio Computers & Internet Experts
Thomas F. Schneider
John Bolton
bigdaddyd2
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
m audio keystation 49e stopped working
  • Computers & Internet
