20 Most Recent M-Audio FireWire 410 External Sound System Questions & Answers
Why sound suddenly corrupted in win or DAW.
That sounds like a buffer issue. Have you tried adjusting the buffers in your recording software? Also virus scanners are known to hog resources and cause garbled audio. Maybe try disabling your virus scanner? Good luck..
6/4/2014 7:49:05 AM • M-Audio FireWire... • Answered on Jun 04, 2014
2answers
Firewire audio problem
Are you using the 410 for recording or as a playback consumer soundcard? Is it connected to external speakers and if so, what type?
Keep me posted.
8/15/2013 7:13:42 PM • M-Audio FireWire... • Answered on Aug 15, 2013
Where can i buy a
Click here for Google's shopping results. Hope this helps =]
3/1/2011 4:24:10 PM • M-Audio FireWire... • Answered on Mar 01, 2011
My M-Audio 410 run well
HI there
I would imagine the drivers from M-Audio are not signed and therefore may not be proven to be compatible with win7. I checked the website and they have drivers for different service pack levels on Vista (I know yours is win7) which is very unusual. This points to them having issues releasing signed off working drivers. Make sure you know what you have installed, 32 or 64 bit win 7. Do not go by the sticker on the case. Go start>control panel>system and look it up philswift_13.jpg
Both versions of 64 bit and 32 bit seem the same file FireWire_6.0.1_5.10.0.5058.exe
which seems weird too
I would uninstall the drivers and choose delete as well
start>search> type 'dev' and see the results. Click on device manager, open it
under sound right click all devices>properties>click on driver tab>
then click uninstall but tick the delete driver box too
then reboot the pc but do not load the driver from M audio
we want Microsofts generic driver to load
After the reboot see if it works.
If not do a system update (start>search>type 'windows u' and click on windows update
Look under optiopnal updates and see if there is one for an audio device and load that
Failing this try the M audio XP driver
If that fails, uninstall and delete as per earlier.
Failing that try the Win 7 driver for 32 bit
Failing that try the Win 7 driver for 64 bit
I think M audio has issues with code for drivers and win 7
http://www.youtube.com/watch?v=anJJ02VV1qs
You may want to look at a new system as it seems M has some bad press with support.
All the best now, but it may be that the drivers are not signed off from Microsoft. If this is the case, you may want to chase up M audio and ask if they can be honest and let you know if there are any issues with Windows 7.
Microsoft are releasing Service Pack for Win 7 first half of 2011 and this may mop-up some issues. http://windows.microsoft.com/en-GB/windows/downloads/service-packs
Phil
12/17/2010 4:24:41 PM • M-Audio FireWire... • Answered on Dec 17, 2010
Hi, i've an m-audio 410
Hi Sir/Madam;
I have provided you the source link to download the M-Audio FireWire 410 driver.
Click Here to download: M -Audio
  • Just click the link below
  • Then choose you device from the list provided
  • Choose the operating system type for which you need the driver
  • Download the driver.
Thank you for using FixYa.
12/10/2010 7:03:44 PM • M-Audio FireWire... • Answered on Dec 10, 2010
Just stopped working. no power. the phantom
Time to replace it.
4/23/2010 11:32:19 PM • M-Audio FireWire... • Answered on Apr 23, 2010
M-Audio 410 driver drops out on internal Firewire port
poested twice
3/24/2010 6:58:52 AM • M-Audio FireWire... • Answered on Mar 24, 2010
The system was previously working properly. But
U just uninstall the audio driver and install it again
1/14/2010 12:05:17 PM • M-Audio FireWire... • Answered on Jan 14, 2010
Has anyone come up with the mac OS-X 10.6.1
I washaving troubles with 410 in my new macbook pro osX10.6.1. I tried to update and... now is not working anymore!
Does any install snow leopard beta driver on regular leopard? Does it works?
10/31/2009 10:58:37 PM • M-Audio FireWire... • Answered on Oct 31, 2009
My (M-AUDIO FW 410)drivers had suddenly got kicked
Unfortunately, you may have to upgrade. Depending how old your system is typically you need to upgrade every 3 to 4 years. You might upgrade your RAM. When you turn on your computer wait at least 5 minutes for all your drivers to load. If you open up an application before they load it may cause a conflict and not load all drivers. Make sure your not connected to the Internet. When your connected to the Internet all your programs that are not set up to not look for updates will. You wont even know that their doing this until it's to late. This is what I would do. Go to your system restore and restore to a point that you knew it was working. When you look at your restore options it will give you a list by day what was added. Just look at these day's and try and remember what you installed before this started happening. You're having a conflicting problem. Now we need to find out where. Feel free to contact me with any other questions. Hope this helps.
JimmyC
9/25/2009 2:46:55 AM • M-Audio FireWire... • Answered on Sep 25, 2009
Rover 620ti
definately operated at 5400rpm, that should be minimum. Those all audio apps recommend recording at 7200rpm, ala 3.5 hard disks. It's the set standard for hard disk recording. The drive is spiining to slow to keep up with system clock speed.
Keep me posted.
7/19/2009 11:57:36 AM • M-Audio FireWire... • Answered on Jul 19, 2009
No Audio output from 410
no idea.any assistance?
5/25/2009 5:01:08 AM • M-Audio FireWire... • Answered on May 25, 2009
M-audio soundcard 410, problems with vista
I had a similar problem, until I turned off my WiFi. I din't want to believe it would be the problem but it sure was, sucks that I cant be online while i'm trying to record something.
Dell Studio 1737
Vista 32
4GB Memory
300 GB SATA Drive
4/2/2009 1:41:30 PM • M-Audio FireWire... • Answered on Apr 02, 2009
3answers
M-audio firewire 410 problem
Hi isterix!
I also have a 410 on a acer 1502 laptop with xp. I installed the latest driver (5.10.00.5053) and i have sound (after changing sound preferences in panel control) but it makes me peaks in the playback. I think it's due to the driver, that is the same also for windows vista. I'll try to install the previous one and i'll tell you!
2/17/2009 10:12:12 AM • M-Audio FireWire... • Answered on Feb 17, 2009
M-Audio FireWire 410 External Sound System Logo
50 questions posted
Top M-Audio Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
m audio 410 run
  • Computers & Internet
