SOURCE: NEC Dterm 80
Press feature; press 9; press #; use key pad to change time; press recall to change am/pm; press feature again to when time correct; new time should show.
SOURCE: NEC DTerm 80
Try dialing the numbers 725 and then hang up...to turn it off..same thing. Ours works this way at work.
SOURCE: NEC D term 80
depends on the system but it should be done in the voicemail. If the names are recorded in than you have to find the mailbox used. If it says please enter the first 3 letters of the persons last name than it is a default mailbox and the names are set in each subscribers mailbox. They have to go into personal options and change the name and letters.
SOURCE: How do I clear a flashing green light on my nec d
It's most likely a line appearence of another phone. When that other phone is ringing it will flash on your phone. If the person is talking on the phone it will go to a solid state.
