SOURCE: lens error 1114
ok if your lans is kinda pointing to one side (like My) you cinda have to pray lol it worked for me love ya god and than you hit your lans to straitin it out and than it will turn on but tha lans still wont go back in so you have to hit it s cupple time down **** so it will go back but not hard dont hit it bck in just kinda lusint it a bit and than turn on the camera and it shuld taike in the lans.
hope i helped
SOURCE: my Sanyo VPC S670 - digital camera lence is stuck
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
SOURCE: mY DIGITAL CAMERA IS A
This is what the Sanyo Customer Service team responded with for me, and it worked:
Take a look at the lens to see if it is crooked or mis-aligned. If it is, with the camera turned off, try to straighten the lens to see if it will click back into place. If it does, turn the camera on and off a couple of times to see if the lens will open and close as normal and then try using the camera as normal.
If the lens is not crooked or straightening does not solve the problem, the camera will need to be serviced.
The warranty coverage period is 90 days for parts and labor.
For non-warranty service, check your yellow pages for camera repair to have a local service technician take a look at the camera for you.
Please consider that the normal out of warranty labor cost can be around $ 75.00, this does not include the cost of parts and return freight upon completion of repairs.
SOURCE: im getting error 1114 because the lens is crooked,
the leans is damaged you want to change it.you will get it from the near by servicing center.
SOURCE: Error 2111 on camera VPC-S750
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
