Broderbund The Print Shop 22 Deluxe Full Version for PC  Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I owned a old version of printshop and cannot find it but I saved files as pdg and pdp. so I purchased printshop version 22 but they will not open them. what do i need to open these files?
juan mercado
Level 2:
Sergeant:
Champion:
  • Expert 222 Answers
  • Posted on Dec 13, 2010
juan mercado
Expert
Level 2:
Sergeant:
Champion:
Answers
222
Questions
Helped
48944
Points
660
Try using adobe reader from adobe.com
2answers
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
2answers
I purchased windows 7 and I have print shop 22 how do I upgrade it to run with windows 7?
Check with Broderbund - either it will work OK - some programmes do or you may have to buy an upgrade - when have you heard that before!!
Will printshop version 22 work with windows7
Hi mfolkart,
Print Shop 22 is compatible with Windows 98 / 2000 / Me / XP
Not sure if Vista or 7 will run it.
Hope this helps...
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
2helpful
I use Windows 7 and the PrintShop Deluxe 22 will not work.
Microsoft's Windows 7 compatibility list shows this product as unknown at this time and recommends using the Vista compatible version. If you need to upgrade to the Vista compatible version there is a free update located at the link below.
http://na6.salesforce.com/_ui/selfservice/pkb/PublicKnowledgeSolution/d?orgId=00D80000000LhUC&id=50180000000AG17&retURL=%2Fsol%2Fpublic%2Fsolutionbrowser.jsp%3Fsearch%3Dprintshop%26cid%3D02n800000009un5%26orgId%3D00D80000000LhUC%26t%3D4&ps=1
I've installed Printshop 21 on my new computer. I
Go to Control Panel,, Click Install New Hardware,, it will search for anything NEW, then ask you if you want it to automatically install the Drivers ! Click YES !
1helpful
Bought new computer. Cannot download my printshop
You might be trying to loading a 32 bit software packege to a 64 bit operating system. See it the store has a 64 bit version. Or you could upgrade the OS with the microsoft pro packege.
Thanks
2answers
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
