Sentry Fireproof Safe Logo
Posted on Dec 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Combination rotation - Sentry Fireproof Safe
tmburke
Level 2:
Novelist:
  • Expert 76 Answers
  • Posted on Dec 12, 2010
tmburke
Expert
Level 2:
Novelist:
Answers
76
Questions
0
Helped
144885
Points
132
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about Sentry Safes at www.SentrySafeShop.com
Reset combination on abus 165/40 padlock
How do i reset the code on an ABUS 145 series combination padlock
  1. Using the existing code, unlock the padlock.
  2. Rotate the unlocked shackle 180 degrees and then press it down.
  3. While the unlocked shackle is depressed manipulate the code wheels to the desired code.
  4. Release the shackle and rotate back 180 degrees.
https://www.lsc.com.au/Products/Padlocks-Hasps-Chain/Padlocks-Accessories/Combination/ABUS-165-Series-Wheel-Combination/16540C.html
Have a small safe with a three number combination. I am not sure how the numbers should be rotated.
Depending on the unit,, Make , Model etc.
It is usually CCW, CW, CCW sometimes 4 rotations to clear
go to first number, then 3 rotations CW to the next number, then 2 rotations CCW to the last number, rotate CW till the tumbler stops,
Then pull the handle to open, if in doubt,
Call a local locksmith who sells or services the unit and ask the
procedure for that model ,
They may be able to set you straight
How do i set lock on axa ntc=95 combination lock
with the lock open (!) (with the right combination set, push the gray buttons backwards so the lock opens), then rotate the right triangular marker clockwise 90 degrees, then turn the numbers to set your new code, then place the right triangular marker back to it's normal position. (rotate back 90degrees counter-clockwise).
Took me a while to find out too...!
1helpful
My baby has turned the screen on my samsung r519. How do I rotate it back?
Usually a combination of key presses like CTRL ALT UP_ARROW
Otherwise will be someting like the following (depends on your video card)Right click on your desk top. Go to Graphics Options, Graphics Properties, and then click on the Rotation Tab. Uncheck the "Enable Rotation" Box. What I believe happened is that your daughter pressed a certain combination of keys, known as "Hot Keys." After you fix your rotation, you may want to disable hot keys to prevent this from happenening again.
1helpful
Key combinations to rotate screen
Deirdre,
The key combination to rotate the screen back to normal is: Ctrl+Alt+Up Arrow
If you use Ctrl+Alt+Arrow keys - whichever arrow key you press is the direction that the screen should rotate.
Hope that helps!
2helpful
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
3helpful
HP 1740 screen image rotated 90 degrees - how to move back
On most video cards the key combinations of ctrl+alt+left arrow, ctrl+alt+right arrow, ctrl+alt+up arrow or ctrl+alt+down arrow will allow you to rotate the screen display in any direction. Each key combination will rotate the screen in the direction of the key press.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
I have lost my instructions to unlock this TARGUS PA400C DEFCON 1 AUDIBLE NOTEBOOK ALARM (PA400C) Do you know where I can find what the default code is?
this may help
Due to the nature of security devices, there is no "magic unlock" code for the Defcon device. To recover a lost combination:
·Set the tumblers to the last known combination.
·While applying pressure to the red release button, rotate the tumblers up one digit and then down one digit on each of the individual tumblers.
·For Example: If your last know combination was 565
1.Set the tumblers to 565
2.Hold the red release button in and rotate the 1st tumbler to 6 so that the combination is now set to 665 (If this is the set combination the red release button will move in)
3.Hold the red release button in and rotate the 1st tumbler to 4 so that the combination is now set to 465
4.If not found move onto the 2nd tumbler and repeat step 1-3
5.If not found move onto the 3rd tumbler and repeat step 1-3
17helpful
3answers
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
