20 Most Recent Sentry Fireproof Safe Questions & Answers
Sentry 3L4300 - Three Drawer 43 Wide Fireproof Resistant Lateral File Cabinet. The drawers are stuck. How can I get into the cabinet?
Hello Jennifer, good to see you again.There is pretty good guarantee and support service on this unit as they are nearly 3 grand new! Go to the website and do the live chat on the top right of the page. You need to know where the locking bars are? Having said that, it sounds like it is a problem with the selective drawer locking.Plunger key lock secures all drawers Drawer-specific "lock/unlock" provision provides additional security by isolating access to specific drawers. https://www.sentryfireproof.com/sentryfireproof/en-US/pdp/3l4300-sentry-three-drawer-43-wide-fireproof-resistant-lateral-file-3hd43-5000-formerly-schwab-3/..
4/12/2024 11:36:41 PM • Sentry Fireproof... • Answered on Apr 12, 2024
2answers
How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
12/21/2023 10:05:19 PM • Sentry Fireproof... • Answered on Dec 21, 2023
12answers
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
5/24/2023 8:29:45 PM • Sentry Fireproof... • Answered on May 24, 2023
Need to open my elsafe safe box. forgot the
I forgot the password to my Elsafe safe box
2/6/2023 10:22:50 AM • Sentry Fireproof... • Answered on Feb 06, 2023
2answers
I had lost my key to my SENTRY 1170 and need my
The fastest thing to do for the portable Sentry Safe 1170 would bring it to bring it to a locksmith and have them pick the lock or fit a key to it.
11/6/2022 4:30:55 PM • Sentry Fireproof... • Answered on Nov 06, 2022
2answers
Can I crack my sentry 2260 safe open by popping the door hinges out?
I can’t open my h060 sentry safe the joy is inside and can’t remember combination
10/19/2022 10:03:00 PM • Sentry Fireproof... • Answered on Oct 19, 2022
0answers
I cannot open my safe.
try holding the # and the * key for 5 seconds that should reset the safe and open it up
9/18/2022 1:14:11 AM • Sentry Fireproof... • Answered on Sep 18, 2022
Sentry safe model MSW3517 won't open after changing batteries
changed batteries and safe wont open
11/15/2021 11:13:31 AM • Sentry Fireproof... • Answered on Nov 15, 2021
2answers
My sentry safe will not
11/4/2021 11:18:19 AM • Sentry Fireproof... • Answered on Nov 04, 2021
3answers
Reset n15115 sandleford safe
i forgot my combination to my 15115 sandleford safe how do i open it
6/12/2021 7:55:40 AM • Sentry Fireproof... • Answered on Jun 12, 2021
Sentry H4100 file safe
There is a lock and there is a latch.
You can latch the safe without locking it and unlocking it does not unlatch it.
After you unlock it, then you must press up on the spring loaded latch while (this important) pressing down on the cover to releast the pressure on the latch hook, allowing it to move out of the way. After the latching hook is out of the way, you can release the pressure on the lid and it will open. You can't see the latch hook as it drops down from the lid, into the front wall of the safe where it engages a post, but perhaps you can imagine what it looks like.
Mine will not unlatch, even though it is unlocked, unless I press down on the lid to give it clearance first. There is quite a bit of spring in the plastic that this safe is constructed out of. It works against you when you try to open it and close it.
I can take digital photos of the mechanism if this description does not help.
Another Gary
2/6/2021 9:37:06 PM • Sentry Fireproof... • Answered on Feb 06, 2021
2answers
I changed the batteries in
Try the factory code shown at the front of your manual. You can find the a user manual on the Sentry website.
1/7/2021 6:48:24 AM • Sentry Fireproof... • Answered on Jan 07, 2021
Error light comes on when keying combination code
Try new batterys ,also sometimes if too full ,you will have to hit it hard to get the stuff off the lock bars that keep them from moving .
11/11/2020 8:28:47 PM • Sentry Fireproof... • Answered on Nov 11, 2020
What is the sentry 6380
I have cracked many codes by just feel and using the lever to feel the drop! The first right turn after three complete revolutions of the dial has one long pause and the rest short! After the long pause is the first in the combination, the left one same thing after one complete revolution, then right again pulling the lever down every drop meticulously. DONE!
10/20/2020 3:35:20 AM • Sentry Fireproof... • Answered on Oct 20, 2020
2answers
Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
7/2/2020 8:19:28 PM • Sentry Fireproof... • Answered on Jul 02, 2020
2answers
Defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
9/8/2019 5:44:47 AM • Sentry Fireproof... • Answered on Sep 08, 2019
2answers
Serial Number Location
Locksmiths agree there might not be a serial# but there is a key # Sentry Safes Keys. Lost your Sentry safe keys. just note your key #(on lock) It's above the keyhole example 3J2, C003B, H,
8/20/2019 5:50:11 PM • Sentry Fireproof... • Answered on Aug 20, 2019
I need help...I opened a Sentry Safe Model 1160 and I need to close it but the lock is stuck and I do not have the key and forgot the combination. How can I close it.
If ya close and dont have a key or know the combination yer never gunna be able to open it again and you'll be really stuffed.
4/5/2019 12:39:05 AM • Sentry Fireproof... • Answered on Apr 05, 2019
1,619 questions posted
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Sentry Home Security
Most Popular Question
reset n15115 sandleford safe
  • Home Security
