SOURCE: Smdr output
Since it's unlikely that the U.K. boys hang out here, try www.pbxinfo.com or http://www.socalphonepros.com/forums/
We don't have 441 in our TA-824 :-)
Carl
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
SOURCE: caller ID/CLIP) not working in Panasonic cordless
Well if the phone has been bought abroad and being used in India you will face this problem. this is because of the format of transmitting the caller id info being different. In USA it is STF and in India it is DTMF. You need a convertor in the phone line which is DTMF to STF. IF you find onw in Delhi pl let me also know.
SOURCE: Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
SOURCE: My panasonic kx-7731 phone only
A TA-824 comes with 4 manuals. One of them is the Programming Manual (PM) http://www.public.carl.airpost.net/Pana/TA-824/300_TA_PM_07-04.pdf and in it there is a description of how to program the system and set up incoming ringing in system programs 408-410 (pdf page 40)
Carl
