Your calculator is giving you the correct answer, telling you that 0.77 to the 22nd is about 3.1827 times ten to the minus 3, or 0.0031827 . By default, the calculator will switch to scientific notation if the magnitude of the number is less than 10 to the minus 2, or 0.01. You can put the switch at 10 to the minus 9 by repeatedly pressing the MODE key until you reach the screen showing "Fix Sci Norm" on the top line. Press 3 to select Norm, then press 2 to select Norm2.
The calculator can only show ten digits. The only way it can show a number with ten or more leading zeroes is to switch to scientific notation.
Testimonial: "Lovely! Now I am able to take my math test without a problem! Thanks darling!"
Type this digits...
(0.77^22)
that's the correct way of putting the digits..
Thanks a million!!!!!!!!
