Heating & Cooling Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this latest ignition module was installed. The furnace is short cycling, meaning it runs often once every 8minutes but for less than 3 minutes at a time. The sequence is as follows: Cycle start (small blower turns on), followed by the ignition module illuminating (yellow) for 3 seconds then turns green and stays constant green thruout the cycle. 15 seconds from cycle start the ignitor turns on then off 45 seconds later as the burners start. The main blower starts 45 seconds after ignition. The burners and ignition module light go off together 2 minutes after ignition. The main blower continues to run for another minute and a half. The whole cycle starts again in 8 minutes. I have already polished the burner sensor, with no effect.
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on Dec 05, 2010
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
580070
Points
4327
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
  • Anonymous Mar 16, 2011
    The flame sensor on the Amana AirCommand 80/80 SSE is connected to a blue wire within the metal box held on with four screws. Disconnect the blue wire, undo the screw holding it to the furnace, and then rotate it approximately 90 degrees to allow it to be pulled out; the flame sensor is shaped like an L.
    Mine had a slight oxidation on it and a little 240 grit sand paper made it perfect in no time!
1helpful
Will a wireless thermostat work with my amana command 80 sse furnace?
Yes. A wireless thermostat will work on your Amana furnace. I like the Honeywell wireless thermostats. The only problem I have had is exceeding the distance between the wireless thermostats location and the control module that you mount and wire up next to the furnace.
I have an Amana Air Command 80 SV Natural Gas fired Furnace that is roughly 19 years old.
it should be above the burner on the outside of the heat exchanger square is shape
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
1helpful
Amana Air Command 80 horizontal central heating furnace; looking for the black plastic small square clips that hold the access doors on...
Hello, I feel your pain as I have busted many of the reducilous tabs myself.You will win the lottery before You get replacements.I use to drill a new hole and install a screw to secure the door.Duct tape works but does not last.
5helpful
2answers
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
3helpful
2answers
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Top Heating & Cooling Experts
Paul Carew
john h
