SOURCE: The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
SOURCE: Miele Premier novo washing machine
Faulty cold inet valve most likely the problem or cold tap off Good luck
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
