SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
thanks.
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
You have to disengage the needle first, by 1. release clutch holding hand wheel and turning clutch knob towards you. The rest goes the same as any machine. I have one and the manual I think you can find a free on the net.
if my answer is not good enough you can always wait for someone else to answer but you are not allowed to post the same question multiple times. As a result your second question has been removed- There is also an alternate answer provided from another user as I suggested. Also please keep in mind- we are not here to look up manuals and instruct you on how to use your product- we help fix problems. We are also by means the manufacture which is where you go for instructions on using a product sold to you. Good luck and
I hope the Brenda Berry was able to answer your question in the way you wanted. as she stated the manual is online- as I provided it to you, reading it would be a great start.https://www.6ya.com/mrmmike
