Get a memory stick then use it to move files from units
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Dell Inspiron 5100 PP07L hard drive
Did you accidentally buy a SATA notebook drive?
If so, this will not work in your notebook, it used IDE drives.
SOURCE: Hard Disk Crash
Actually if the hd is corrupted, you can try to go to safe mode or do a chkdsk and then fix boot otherwise you need to contact drivesavers for that.
SOURCE: I have a DELL LAPTOP . Latitude D430 ,
When the pass word box comes up do not put any thing in there and press enter or Three other things you can do take it back and ask for the Administration Password Second access the Bios and you may be able to over ride it or access the Bios battery and that my help BUT I would try the first one
SOURCE: Can my hard drive be salvaged?
You can definitely get another one, as long as it's compatible with your system...get the original specs from dell, then search online at western digital, tiger direct, etc. etc.Many online sites will have recommendations for your system.
Please consult links here and here
You may want to run chkdsk to see what's up with it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: smart failure predicted on hard disk 4
Yes usually that error means that the hard drive is telling the controller card that there are some problems with the drive.
Although the drive may still work, it is highly recommended to replace it with a new drive.
I would replace the drive but keep the old drive just in case, after re-installing Vista you find that there is additional data you did not backup or remember to backup.
Just replace the drive, and if it's a Dell laptop, use the Dell Vista reinstallation DVD, and it will not ask for a keycode to reinstall.
May also want to go to another computer and go to support.dell.com and click Drivers and Downloads. Type the service tag and go ahead and download all drivers needed (i.e. network card, sound card, etc.) so after you reinstall Vista, if there are any drivers missing you will be ready to install them.
Hope this helps.
