20 Most Recent
Dell Vostro 1510 Notebook Questions & Answers
Dell laptop powes up no video
This could be one of three things.1. It could be the LCD screen has gone out.2. It could be the Cable that runs to the LCD has gone out.3. It could be the Video Card has gone out.If you have an extra computer monitor you should be able to hook your laptop up to it. That would help cross out bad Video Card. Truth be told any of these issues will have to be serviced.
Error light
Have you tried a desktop keyboard with usb plug? to see if the computer will allow access.
Listing of preferred wireless network for DELL 1510
right click on on status bar and then property and then customize and then you will see wireless icon and then make it visible all the time.perhaps you did turn off windows zero configuration. to do that right click my computer then manage the services , and then in service start windows zero configuration
Proper technique for cleaning screen
I use end dust anti static cleaner can be found at any local supermarket always spray on a soft cloth never direct on the screen. You can also use anti static wipes any computer store will have them just never spray direct fluids or anything that is greasy or things like brake cleaner use those two items you will never fail to keep it clean without destroying it. Be gentle and make sure that the computer is turned off and remove the battery so that you will not hit the power button while cleaning computer if you do the screen do the keyboard as well and blow out the cooling fan area as well dust is a problem for fires and conducts electricity. Cleaning is critical I clean my machines once a month. I have never had any issues with my machines running bad. John
Cd player won't eject
Look at the front of the CD drive, there should be a small pin hole. Take and straighten out a paperclip. Push the paperclip inside the pin hole and lightly push. The tray should open slightly. Then just manually pull the tray out and remove the disc.
Xp sp3 sees it but no searching sounds for disc
Download this Microsoft UAA Bus driver for high definition Audio bus.
Below is the link
http://america.giga-byte.com/FileList/Driver/motherboard_driver_audio_realtek_azalia.exe
Installe dthe above software first.
And installed your driver, your sound card will work fine.
Two O.S.
put the windows xp cd into ur dvd writer ...
restart the machine...
then after showing the dell logo...
it will say
"press any key to boot from cd.."
press any key..
wait until a blue screen appears...
there will be three options
choose "press esc for a clean install"
it will show the partitions of installed windows
delete the partition of your choice....
create a new partition on the unallocated space...
press f3 to quit...
machine will restart ...
wait upto the blue screen...now choose
"press R for recovery console"
press R
type fixboot | enter
type fixmbr | enter
restart the machine
whoa...your are good to go..
