Jade RJDG3610A Stainless Steel  Cooktop Logo
Posted on Sep 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the drop in Jade 5 burner cooktop. for the first time, I noticed a significant gas smell when I light any of the burners. we cant figure out the problem since the cootkop is functioning fine, but smells like gas as soon as we light it. The gas lines dont smell. It only smells when we light the burners? Any help is much appreciated. Anyone have the same issues?
marlin siecinski
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 512 Answers
  • Posted on Oct 02, 2017
marlin siecinski
Expert
Level 2:
Prodigy:
Answers
512
Questions
Helped
160431
Points
715
All gas burners will put off a gas Oder when lit, if you go away for a while and come back home and smell gas, you should turn off the gas and call the gas company
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Nov 20, 2007
SOURCE: jenn air electric cooktop
first, disable power to cooktop. next, replace either the mangled burner or the entire unit (after initial inspection leads to a logical prognosis)...sorry.
Anonymous
  • 135 Answers
  • Posted on Apr 07, 2008
SOURCE: Gas cooktop BOOM
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Anonymous
  • 408 Answers
  • Posted on Mar 04, 2009
SOURCE: Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
gerbee gomez
  • 222 Answers
  • Posted on Sep 13, 2009
SOURCE: I cleaned my viking 6 burner gas cooktop and now
how u clean it,u think you never damage the gas line? call the person how to resolve the gas leak if we have.
tnx.gerbee
Gil Shultz
  • 3464 Answers
  • Posted on Nov 25, 2014
SOURCE: I have a Jade cooktop model RJSG3610A and need a burner base/electrode Mfg. Part # 70002826. No one sells this part as they say all discontinued. Do I have to replace entire cooktop or is there anot
Check with an apliance parts store they may have an alternate for you.
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
4helpful
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
1helpful
2answers
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Whirlpool Cooktop Burners do not light
Hi Scott,
Please view the link and videos below.
http://producthelp.whirlpool.com/Cooking/Cooktops/Cooktop_Product_Assistance/Cause_of_gas_burners_not_igniting%2C_lighting%2C_clicking_or_ticking
Searching youtube can often provide many helpful videos that clearly explain how to repair such issues.
Good Luck.
Gas burners lit, but electronic ignition still clicks
heatman101
fsggfs
Gas cooktop BOOM
Apr 03, 2008 • Cooktops
5helpful
2answers
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Top Jade Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Jade Cooktop Expert? Answer questions, earn points and help others
