20 Most Recent GE 36 in. Monogram ZEU769 Electric Cooktop Questions & Answers
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
GE 36 in.... | Answered on Sep 30, 2010
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
GE 36 in.... | Answered on Aug 28, 2009
most likely the keypad is defective.
GE Cooktops | Answered on Oct 03, 2019
The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element.
Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
GE Cooktops | Answered on Jan 09, 2019
There are several helpful how-to videos on Youtube but please be aware induction hobs work on a principle different from the usual and the troubleshooting and repair is considered a specialist task - if you wouldn't poke around inside a tv or a computer then you probably shouldn't poke around inside your hob.
GE Cooktops | Answered on Dec 02, 2018
Probably a power line transient turned the light on.
GE Cooktops | Answered on Sep 17, 2018
GE 36 in. Monogram ZEU769 Electric Cooktop Logo
13 questions posted
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
gas burners lit but electronic ignition
  • Cooktops
