Samsung RS2630SH Side by Side Refrigerator Logo
Posted on Nov 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My fridge keeps beeping even though the door is shut. The fridge temperature indicator keeps going up and then down. Can you please tell me what's wrong?
Dave R
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 22, 2017
Dave R
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
38009
Points
5
If the reset procedures don't stop the beeping and you are out of warranty, here is an easy fix:
1- (You can unplug the fridge just to be cautious, but not necessary.) Remove the control panel from the front of the fridge. Mine pulls straight out without removing any screws.
2- On the back of the control panel is a black, round device - the only thing that pokes through the back of the panel. This device is small, maybe 1/2" in diameter and the same deep. (if it won't pop off easily, remove the 4 screws to remove the back cover for easier access.)
3- You will see a thin round disk inside. This is the speaker. Remove this disk, press the black speaker cover back on and press the control panel back into the front of the fridge.
All the controls will continue to work as before, but NO BEEPS!
Yea!
Kelly
Level 3:
  • Samsung Master 3,740 Answers
  • Posted on Nov 08, 2010
Kelly
Samsung Master
Level 3:
Answers
3740
Questions
Helped
2163453
Points
12091
Is the beeping a door or temp alarm? You can press power cool and power freeze buttons at the same time and you should get a single LED indication and then after 30 seconds the
display should return to normal. NOTE the position of that single LED should you see it.
1) Self-Diagnostics in the initial Power ON
1-1)The control board performs a self diagnostics test within 1 second and check out the temperature sensors abilities.
1-2) If a sensor failure occurs, a corresponding LED segment will blink with a beep.
1-3) When a LED segment blinks, only the cancellation function (Press Power Freeze and Power Cool buttons
simultaneously for 8 seconds) is acceptable.
1-4) After a replacement of bad sensor or a cancellation of this function, this self diagnostics will end.
2) Self-Diagnostics in the normal operation
2-1) To select this function, press Power Freeze and Power Cool buttons simultaneously for 8 seconds with an audible tone.
2-2) In the self diagnostic mode, only corresponding LED segments will be illuminated (see the check list on the next page) <NOT in this post Interpreting LED position = these errors below. You will need to pass on / reply with exact position of the LED that you see
1 ICE MAKER SENSOR
2 REFRIGERATOR SENSOR
3 REFRIGERATOR DEFROST SENSOR
4 REFRIGERATOR FAN ERROR
5 ICE MAKER function error
6 CoolSelect ZoneTM SENSOR
7 REFRIGERATOR DEFROST ERROR
8 EXIT-SENSOR
9 FREEZER SENSOR
10 FREEZER DEFROST ERROR
11 FREEZER FAN ERROR
12 CONDENSER FAN ERROR
13 FREEZER DEFROST ERROR
2-3) After a 30 second illumination of error signal, the system will return to the normal operation.
I suspect a thermistor problem.
The unit will self diagnose if you unplug it for 15 to 20 minutes and then plug it back in. ANY errors will be displayed by a single LED (digit) indication during the first 14 seconds after you plug in the unit.
You must wait that 15 - 20 minutes of unplugged time to prevent the compressor overload from tripping due to high coolant pressures. System must stabilize first to prevent damage to your unit.
Thanks for choosing FixYa,
Kelly
  • 2 more comments
  • Kelly
    Kelly Nov 08, 2010
    Forgot this info:
    2) Door Open Alarm
    2-1) When the doors remain open for 2 minutes, there are 10 times beeps.
    2-2) If the doors continue to remain open more than 2 minutes, the additional 10 beeps interval will change to 1 minute. (A bad door switch will cause unit to beep once a minute over a long period.)
    2-3) The beeps will cease immediately when the doors are closed.
    Kelly
    Forgot this info:
    2) Door Open Alarm
    Kelly
  • Amanda Snead
    Amanda Snead Sep 06, 2014
    could a bad door sensor cause the ice maker not to work?
  • Myles Scranton
    Myles Scranton Oct 21, 2017
    So what error is the one with the 12 little squares and water driplet on it
  • Roelette Spies
    Roelette Spies Jul 19, 2020
    After loadshedding my Samsung fridge give an alarm stating that the temperature is cooler outside then the fridge setting is.. When you open the door the display changes to the highest possible temp settings but returns to normal when you close the door.. The light does not work when alarm goes off...
Maytag fridge bepping lights out MFI2568AES...fridge and freezer working..what could it be... Beeping all night long..
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
Cause of Beeping Noise in Frigidaire Refrigerator eHow Refrigeration System Basics Chapter 1
Snowmaster BD60DE keeps on beeping while doors are shut
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Read more :
E240B Fridge Freezer door open alarm goes even when door closed.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Fridge keeps bleeping
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Beeps about 6 times when fridge door is opened.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
