Stoves Premier 720EMa Electric Double Oven Logo
Posted on Oct 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi Top oven only gets warm no matter where you set
Hi Top oven only gets warm no matter where you set the temperature control. Tried a new thermostat but still no good. The top grill works ok, so could it be the top oven element
Anonymous
Level 2:
  • Expert 250 Answers
  • Posted on Oct 30, 2010
Anonymous
Expert
Level 2:
Answers
250
Questions
5
Helped
143594
Points
506
I have a 720ef and the top oven is not that good. The wattage rating is low, from memory about 750 watts and it takes a month of Sundays to warm up. I bought an oven thermometer from Lakeland a little while ago and when the top oven is turned on the Lakeland thermometer is showing that the oven thermomostat is running the oven at 20 degrees below what it is set to. If the thermostat neon is clicking off and on, then the thermostat/oven is working, albeit not as we expect.
Kenmore 7909445 oven not reaching specified temperature?
The User's Manual says that the minimum temperatures for most settings is 170F. If those are also the defaults, the oven controls might have forgotten their settings and might need to be reset. If resetting the controls doesn't work, you might want to try checking the temperature sensor; sensors go more frequently than control panels do. I have included a link to the User's Manual I found.
http://www.saferproducts.gov/Common/Pages/DisplayDocument.aspx?documentId=294072
1helpful
Zanussi ZKC6040
You need a new thermostat control for the oven fan. That is what determines when the temperature of the oven is low enough that the fan is no longer needed. Based on your description, the thermostat has failed in the "closed" position which means that it is always supplying power to the fan.
Ge profile JPB90W S2WW convection self cleaning
They do charge a fortune for parts. Get the part number for the controller and then log it into ebay. Often you can get the parts there for a much better price. Otherwise repair will not be cost effective unless the part is dirt cheap. Yeah, right!
Sep 15, 2017 • GE Ovens
6helpful
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
My oven will not heat up, at best it may get warm. Please help
one of three possibilities: a hotspot in element(check for pitted discolored area in element)where current cant get thru/defective thermocouple(controls oven temp cycling) bad oven temp control(control you set for temperature
3helpful
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 • Ovens
    Oven overheating
    I have just purchased a new thermostat and installed it. The oven now works fine and the heat light cut in and out showing temperature is being controlled.
    Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
    Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
    Top Stoves Ovens Experts
    ZJ Limited
    ZJ Limited
    vince
    Are you a Stoves Oven Expert? Answer questions, earn points and help others
