20 Most Recent
Viking 27" Professional Select Built-in Electric Double Wall Oven - VEDO127 Questions & Answers
Oven door won't open after self cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
How long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
