This is normal. The reason it raises higher is due to the design of the sliding arms in the moon roof. without going into too much detail, the reason it raises before closing is to "unlock" itself from from the "Locked" open Position in order to get to the "Locked" closed position. Its a fancy way of making it seal well when closed and not rattle when open
This has no problem to do with the phone as far as i know.
It occurs normally when you are talking to someone who happens to be in a very quite and large room without that it empty. this is due to the empty vaccumm that causes the sound that is produced to be reflected back into themic of the phone and as a result causes you to hear your voice.
Also, another thing that causes it is when you talk to someone who puts the call on loudspeaker and there are multiple surfaces causing the reflection of the sounds you make.
In summary, there is nothing wrong with your phone and you just need to tell whoever you are talking to to try and move to an area that is a bit occupied so as to prevent echoes.
this phone has many different volumes to play with, one of them is the volume for, when your calling someone, simply, when you call someone, press the volume up button, and you should hear the person louder
check all of the vaccum lines and check the timing and see if they have any thing at the auto store for diesel to put in the tank you may have also got a bad tank of diesel fuel. i also had something like this once happen to me and the tank i got it was not diesel someone had put unleaded in that tank by mistake
