Because of the importance of transferring contact information from one communication vehicle to another, there are a number of different automated ways to transfer contact information. To import contacts, such as VCF files from computer to Samsung Galaxy S9/S8/S7/S6/S6 Edge, you need to ask help from an Android data transferring program named
MobiKin Assistant for Android or
Assistant for Android (Mac Version). With it, you can move contacts between your Samsung Android phone and computer in 1 click.
Step 1. Click the above button to download and install MobiKin Assistant for Android on your Windows or Mac computer according to its prompt instructions. Then, launch it directly. After that, you'll be required to connect your Android phone to computer with USB cable or WiFi. Just choose the method for connecting as you like.
Step 2. After connection, you need to do some operations to make the device be recognized by the program. For example, you need to
open USB debugging under "Developer" option, and install a right USB driver on the PC. (Sometimes you may need to install the USB driver manually due to unknown reasons when the automatic operation is not working well.)
Step 3. When your Android is recognized by the Android Assistant software, you can see an interface like below. Now, directly click "Super Toolkit" in the top menu, and select "Backup" option.
Step 4. Check the device and click "Contacts", then specify an output folder according to your needs. After that, click "Back Up" button to begin the process.
Complete procedure can be found on below link:
5 Ways How to Backup Android Contacts
Learn More:
How to Import Contacts to Samsung Galaxy S9 S8 S7 S6 Edge
