You just need to change your screen resolution to fit the monitor. Right click an empty spot on the desktop and left click on Properties. This will bring up your Display Properties. Click the Settings Tab at the top right and you will see a slider bar on the middle left. Move the slider bar to the right or left one bit at a time and hit the "Apply" button. The screen resolution will change and if it does not look right, then cancel the change and go to the nest resolution setting. Repeat this process till you get a resolution that works well with your monitor. Cheers!
