Hi Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Please note that dishwashers don't drain out the complete water such that heating element doesn
Hi
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
