SOURCE: downloading itunes software
you can try a download manager ,, just google download manager and choose one that you think will works for you,,, they have trials aviable you can use one of them...
SOURCE: windows XP logo testing
Also, try installing the drivers in Safe Mode logged in as Administrator.(default is no password)
SOURCE: Unable to start in Safe Mode with Command Prompt in XP Media Center 2005
Hi there. My name is Alex and I am here to help solve this problem
Depending if the BIOS has legacy USB support for keyboard and mouse enabled, you should be able to run safe mode by pressing F8 before the computer boots into windows. I would not recommend going into the BIOS if you do not have much knowledge to the computer as one wrong configuration could cause some behaviour problems or even damage to the pc's components
I recommend connecting a keyboard and mouse that have cable and the PS/2 connectors (purple and green) which can be found at back of the computer at the top. Then restart your computer, hold down F8 and you will be able to run safe mode. The mouse and keyboard will then work
Keep both the keyboard and mouse plugged in and boot windows. When you get into windows, plug in the USB keyboard and mouse into a USB slot and wait whilst it detects it. After a couple of minutes you should be able to use your USB mouse and keyboard and take out the PS/2 keyboard and mouse
I hope this has helped. Please let me know if you have any questions or need further assistance.
SOURCE: Can't connect to the internet new hard drive
You need the Intel Pro 100 driver for XP. Go to the following web link at Intel: http://www.intel.com/p/en_US/support/highlights/network/pro100ve and download the driver. Copy it to a flash drive. Put the flash drive into your PC that needs the LAN driver and double-click it to install it.
Testimonial: "worked as advertised, thanks for the advise. Iam not connected"
