20 Most Recent
HP DeskJet 712c InkJet Printer Questions & Answers
Installed new ink carterages
Hello Plugger 732,
We need more information on the issue.
Please let me know if you see any blinking lights on the printer.
Below go through below web page . it is HP Support web page on this Printer issues.
http://tinyurl.com/4ewhn6g
let me know further if you have any issues.
My HP DeskJet 712c InkJet
Hello.
Give this a try:
1. Power off your printer
2. Remove and reinsert the cartridges. You should hear a "click" when properly seated.
3. Power on printer.
4. If light is out, print a test page for realignment.
Note: Be certain that the tab is removed from the cartridges and you are using "genuine" HP cartridges.
Hope this helps.
Wont print
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and
go directly to downloading the tool
Connectivity
USB: Ensures that the USB connection from your computer to the HP product is working correctly.
Network:
Ensures that the network connection between your computer and your
network is working correctly. If the tool detects a network connectivity
problem, you will be prompted to run the HP Network Diagnostic Utility
for better results.
Spooler
: Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
Online status
: Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
Device manager
: Checks for problems in Device Manager that would prevent printing.
Print queue
: Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
Port
: Checks the port settings for the HP product.
Driver
: Checks for alternate-driver settings.
Conflicts
: Checks for conflicts with other drivers, such as other printer brands.
Default printer
: Checks the default printer setting and prompts to select the HP product as default (optional).
My inkjet printer is not feeding paper properly.
I would check for little bits of paper stuck on the roller. Did you have a paper jam prior to this problem? Using a good flash light, look for, and remove any little pieces that you might find.
My hp 712c printer prints only the pink band when
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
My friend has an HP 712C printer that I gave him.
According to
HP's Website ...
"The driver solution for this product is included in your Windows XP operating system and is already on your computer.
There is no need to download anything. Follow the steps below to quickly and easily get your product working with Windows XP."
But the info on how to get it to work if having issues if also found on that page.
Every time I try to print something it says I
I have had this problem before using Windows XP. I disconnected the printer and went to my computer then printer and faxes and deleted all the icons. I re-connected the printer and one printer popped up. I right clicked and set as default. It should say "ready" next to it. Deleting the Icon does not delete the printer driver. Hope this helps.
Trying to install HP Deskjet 712c on computer with windows xp
You shouldn't need any software to print to this printer under XP, just let XP find the best or closest match to your printer and install it. It might be a Deskjet 700 or something but it'll work as a printer. The old software was probably for Windows 98.
