What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful: 1. Charge your Jabra BT135 until the solid blue LED turns off (approximately 2 hours) 2. Make sure the Jabra BT135 is switched off 3. To put the Jabra BT135 in pairing mode, press and hold the multifunction button until the LED stops flashing and turns solid blue 4. Set your mobile phone to "discover" the Jabra BT135 (see your phone user guide) 5. Press Yes or OK when asked if you want to pair the phone with the Jabra BT135 6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK 7. Your phone will confirm when pairing is complete and your headset will flash
For more details, download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step. http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
It will
tell you how to set it for discovery mode to pair with your Blackberry. And, remember to bookmark
the page.
If I remember correctly, on your phone, go to settings > connections > bluetooth (turn on) and select discovery mode to pair your headset.
The user guide for your headset is in PDF Format so it may take a minute for the page
to load. If you need a PDF Reader to view it you can download Adobe
Reader for free: http://get.adobe.com/reader/
If
you found this information helpful, please give me a big thumbs up when
you rate my answer. Thanks.
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
