Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Posted on Jun 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red/Green shadow on bottom left side of screen
The bottom left side of our TV has a red/green shadow, meaning everything viewed as words or picture are in these colors, and has a wiggly or mis-aligned shadow. We have tried aligning the crosses, and finally found the "reset to factory" mode. This still didn't work. Any help would be appreciate, this TV is only 4 years old...
  • 5 more comments
  • stevensnyder Jul 13, 2008
    i have the same problem, it seems kinda common, the red color alignment is off at the bottom left side of the screen, would like some help.
  • Anonymous Jul 23, 2008
    kl;kl;kl;kl;
  • Anonymous Aug 13, 2008
    Same problem here.... I believe it will involve replacing of the convergence ICs. I found it in the previous post. My TV is 4 years old as well. Ouch...
  • miller84 Oct 20, 2008
    Amazing. Mine is 4 years old too and has the same problem. The tech is estimating $250 for a convergence board and $250 to put it in, plust the $100 service call.
  • Anonymous Nov 07, 2008
    its broke
  • Anonymous Nov 11, 2008
    i have the red n bottom lrft mine is 6 yrs old it started a year and a half ago, also blueish blurry screen convergence didnt help much.
  • Anonymous Dec 29, 2008
    the picture wont align and the color is screwey
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
225
Points
Ours is 4 yrs old too! How much did this cost?
Anonymous
Level 2:
  • Expert 138 Answers
  • Posted on Aug 19, 2008
Anonymous
Expert
Level 2:
Answers
138
Questions
0
Helped
39742
Points
190
Yes to allthe probleis the convergence IC'S
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
1helpful
Tv gets a red and green shadow on the left side after being on.
convergence solder connections likely going bad. you may be able to resolder or just replace the chips.
check my tutorial and let me know if you need more help.
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Picture has a red shadow. especially
Convergence problem on rear projection CRT TVs.
Red & green shadows
Replace the two STK392-120 Convergence Ics you can get replacements at the following link with step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
2answers
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
2answers
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
