How to Unlock Black Berry 9530
Just Go to
Unlock blackberry Phone How to Unlock blackberry Phone
Make your selection like model->country->network-> Mail ID and update IMEI by login to the unlockninja portal
code will be delivered with in 1-2 business days
How to use the unlock code
How to Unlock the ZTE MF60
1) Insert a non compatible SIM card to your locked ZTE Cell Phone,
2) Phone will prompt for Unlock Code (NP Code),
3) Enter the Unlock Code you received.
SOURCE: i have this black berry
might be your phone is locked to your previous provider. you need to unlock your phone to use it with other phone. you can unlock your phone through codes. its the simple and the best way to unlock any phone. i got my phone unlocked using codes. you can get the codes from your service provider itself unless your phone is not more than 6 months to 1 year. else you need to purchase codes from third party vendors who provide codes at reliable rates. try this site to get the codes. i purchased the codes from here SuperUnlockCodes only since my phone is older model.
SOURCE: i got a blackberry 9530
To be able to use the phone on other GSM carriers worldwide,go to
Unlock Verizon Blackberry Storm 9530
SOURCE: need puk code for verizon
Welcome to Fixya. The PUK (Personal Unblocking Key) is a SIM-specific code assigned by the service provider. It is near-impossible to guess and enter it; thus, if a user does not know his or her PUK and is prompted for it, it should be obtained from the service provider. The code is not caused by the phone but the sim card. You can just remove and replace the simcard of the phone and the PUK code will be gone. In you case if you will be using a T-Mobile sim to your BB 9530 if the black berry is locked to Verizon there's no way you can use a t-mobile sim. You can request the unlock code of your phone from a third party unlocker. PUK and unlock code for you to use a different sim card is different from each other.
If you have questions please let me know. Thanks
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
SOURCE: I just got a verizon
Etisalat Nigeria do not work with certain branded Balckberry devices. E.g the Tour 9630.The better option you've got is to switch your network or your telecom operator. MTN & glo work with branded devices. Let me know if you have a better solution because I also had the same problem
