The starter can be removed from under the vehicle.
But before doing anything,first disconnect the negative terminal of the car battery.Do start the procedure with battery connected.
The starter is located on the frame rail on the driver's side. Lift the car up on jack stands.Give proper support to the car before working under the car to locate and remove the starter.Now before removing the starter you will have to remove the upper intake manifold bracket .This manifold bracket is held by 4 screws,remove those screws first to loose the upper intake manifold bracket.Then remove the wiring connections from starter solenoid mounted on the top of the starter motor.There are two wiring connectors remove both.Both the wiring connectors are fitted by a nut.Remove both the nuts and loosen both the wiring connector.Now loosen the starter connecting bolts and remove the starter carefully from the engine compartment.In the reverse procedure reconnect the new/replacement starter and complete the procedure.
Keep updated for any more queries.Thanks.
SOURCE: Starter?
It should be on the passenger lower side you may have to get vehicle up in the air and take off splash sheild theier are jus retainers hold it in and the lower front engine under cover/ Please rate my response Thank you very much
SOURCE: NEED TO CHANGE THERMOSTAT ON 03 KIA SEDONA. INSTRUCTIONS?
Here is a link:
http://wiki.answers.com/Q/Where_is_the_thermostat_and_how_do_you_change_it_on_a_2003_Kia_Sedona
SOURCE: how do you change the right front headlight bulb on a kia sedona
Remove the headlight assembly. Just remove the 3 bolts with a 10 mm socket and pull it out so you can disconect the wire harness. After that pull the whole assembly out and unscrew the bulb cover. The bulb is held in with a spring clip.
SOURCE: Cam belt change on a kia sedona recommended milage
The recommended interval for changing the timing belt is in the owner's manual. Generally, this is every 60,000 miles.
Charlie
P.S. I found the data on the internet and, it is indeed 60,000 miles.
SOURCE: How to change the oil on a 2005 Kia Sedona
The oil filter is towards the front of the car, underneath on the passenger side, at the corner of the engine cradle. Loosen the drain plug and drain the oil. Make sure the old oil filter gasket came off with the oil filter. Reinstall the new oil filter. Reinstall the drain plug and fill with 5 quarts of 10w/30 motor oil.
