Sony 32" tv red light flashes then picture blinks on and off continuesly
Seems everyone is having issue with tv blinking on and off. red led at bottom blinks for about 3min. then red light stops and picture comes on but does not stay as it contiuousley comes on and off
There is a system error then. If a red LED is blinking and the TV is not working properly it means that the TV has detected an issue or problem. Most of the Red LED blink conditions will require being service. Check how many times the red LED light will blink and then contact Sony for support.
The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Sony has provided a "self-diagnosis function"
with your TV, that in the case of abnormalities or problems the LED or
red blinking light on the Timer/Standby indicator flashes a number of
times to indicate the issue. when there is trouble with your
Sony Television set -- it indicates the issue in either the diagnostic
mode, or even more commonly by flashing a series of LED blinks or
flashes on the front of your television. Each set or frequency of the
blinks indicates a very specific problem with the television itself. Sorry but unless you may be able to repair the television set yourself , please call a local repair shop
to the have a repairman sent out,, Take care and please Remember to rate/vote for us to continue for Helping out the Community :)
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV. I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
same issue. flashing screen
HELP
