Cell Phones Logo
Posted on Oct 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the manual that came with my jabra blue tooth
Anonymous
Level 2:
Sergeant:
  • Expert 270 Answers
  • Posted on Oct 08, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
270
Questions
0
Helped
68583
Points
864
Having the model number of the Jabra would be extremely helpful.
Most Bluetooth devices have a default pairing ID of 0000.
As for turning the volume UP or down, depending on what ear it is worn on, is nothing but trial and error.
Turn on your phone, go to settings (or tools) and turn on bluetooth. Select find device:
Turn bluetooth JABRA on and HOLD the power button until the Jabra flashes. (this means it is sending a bluetooth signal) Your phone should see it and ask for a pairing code. Enter 0000
A message on your phone should indicate you are paired.
Good luck.
I have no codes in my manual which came with my Jabra Style. Have even downloaded the pdf manual, still no codes. Can you tell me how I can use this app please?
Usually the Jabra headset connects via blue tooth. You pair it with a smart phone once. No codes other than the pairing number you see on the phone when starting the pairing process.
1helpful
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
How do I pair my ;Jabra A335W Blue Tooth,to my;Windows 8.1 ASUS 2014 Lap-Top?
http://www.youtube.com/watch?v=C5koqNKSjB8
I could try and explain it but this video link below explains it reaaly well
http://www.youtube.com/watch?v=qUtvbRSx00A
laptop has to have bluetooth ability if it doesn't get an usb bluetooth adapter
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
1helpful
I need pass key for Jabra BT530 to pair with cell phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 06, 2010 • Cell Phones
1helpful
Unable to make or receive calls using Bluetooth.
try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
Jun 25, 2009 • Cell Phones
5helpful
Jabra VBT2050 Not detecting
On The Blue Tooth You Have To Hold The On Off Till The Light Flash's Blue Red Over And Over Then Search For It On Your Phone.
Once You Find It It Will Be Recognized For Now On. Just Hit The Button On The Blue Tooth One More Time To Stop The Sync Mode.
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
