Mitsubishi WS-55907 55" Rear Projection Television Logo
Posted on May 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV will not turn on.
I have a WS-55907 that will not turn on at all. When I plug it into the wall it sounds like it is getting power. Checked the fuse at the power cord and it is good. Any suggestions?
  • Brandonfire5 May 27, 2008
    Does anyone have a schematic for the WS-55907?
  • kennethstrze Nov 29, 2008
    WHEN I PRESS THE ON BUTTON,TURNS GREEN. IHEAR A CLICK THEN TV SHUTS OFF. CHECKED THE FUSE BY POWER CORD.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
448
Points
Same problem and Just had repair man out. Said it was the signal board and that with this model it is a very common problem. Mitsubishi no longer makes the parts to fix it. If you want to scout online for one th product number for a signal board is 930b868003
  • Billkneale May 02, 2011
    If it is clicking you need to check the power Circuits both switched and un-switched. If I had to guess you have lost you 24pos or negative voltage. both circuits have a diode and a fuse on the board that need to be checked. If the diode is bad you must replace it the the same Ultra High speed type.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 346 Answers
  • Posted on May 27, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
346
Questions
Helped
91356
Points
559
Check power converter/regulator
WS-55907
1)Pull chassis or center PC board
2)Replace STK392-570 IC's
3)Locate green soldered-in pico fuses = use ohm meter
to find which ones are open ( bad ) = replace
4)Reassemble, test
My tv you can hear it but not see the picure what should I do to fix it?
try to adjust the contrast on your remote maybe it was accidentally turn to black or just send your TV to a technical person to prevent further damage.
Hope it helps. Thnaks
Can't get VGA adapter to work from labtop to Mitsubishi WS-55907 TV
If the TV has a VGA input it should work by simply striking the function key and the crt or monitor function **** on your f keys listed in blue.
2answers
Error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
http://servicemanuals.vstore.ca/
Double vision
convergence fail. try resoldering the 2 convergence ICs in the middle baord located on the large heatsink. this might fix unless the problem has gone it course
3answers
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Tv powers on and goes off after about 3 seconds
This set has a problem in the horizontal sweep circuit or in the main power supply. Most likely a failed component, and the set shut down to protect the rest of the circuit. If you know how to read a schematic diagram and how the circuits operate, then you will need a good multimeter and an ESR type capacitor checker to find out the short in this set. Sometimes the CRTs(Picture Tubes) will leak the coolent fluid out and onto the printed circuit boards. Also sometimes the convergence IC's can cause this problem, but if that is the case the small little pico fuses will pop also. If you have had no solid state or printed circuit repair experience, play it safe and call in a trained tech. Good Luck
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
