20 Most Recent
Mitsubishi WS-55907 55" Rear Projection Television Questions & Answers
HDTV comes up green
there is a setting in the menu under setup i believe it is called "LABEL VIDEO INPUTS". check you owners manual. you need to make sure that the DTV input is set to YPbPr NOT RGB.
How do i turn on screen saver?
Set listed here does not have one---if using HD avoid using the 4X3 (narrow picture left to right) as the borders if left on too long with contrast too high will burn the tubes.The Default settings on the set listed here are if set unplugged and plugged in : Contrast 100%---this is what burns in images left stationary too long--never have contrast (picture) set above 75 percent.
When I turn tv on
hi sir good day
here is my solution, since your unit is turn on then turn off you need to check first the power supply look for shorted component at the same time capacitors with bulging on top to its casing it cause a voltage drop. replaced it with the same value a panasonic FM or FC series much better with low ESR. you can find replacement parts at
www.digikey.com. now check also the ballast board for the lamp which cause the clicking if their is a bad component here the board will turn off then their is no picture.hope this may help thanks for consulting us feel free to ask further question.
The picture on my tv
The problem of your tv is the convergence. Use the original remote then go to setting menu then you will see the convergence section. Try to adjust the color, you should move them left,right and up,down. If this color does't move far enough the convergence chip is defective and must be replace. This convergence chip is located inside the tv t has a large aluminum plate cold the hit sink and the chip has a marking of STK---followed by numbers if you are handy in electronic trouble shooting I can guide you but be sure to unplug the unit first or you can contact a technician to do it for and save you from stress. Good day and best regards.
TV will not turn on.
Same problem and Just had repair man out. Said it was the signal board and that with this model it is a very common problem. Mitsubishi no longer makes the parts to fix it. If you want to scout online for one th product number for a signal board is 930b868003
It turns on than of immediately.
maybe theres a shorted parts in the power supply.causing the power not to osolate. you need a costomer support technician to fix your problem.
My TV color has yellow, blue and red shadows n the picture.
Enter Service mode.. Press Menu -0-1-5-7 in quick succession . From there select the convergence option. You should see 3 crosshairs -Red, Blue and Green. Green is fixed but Red and blue can be moved. Align both of them with green and see if the issue resolves. If not Try moving them around and see if the problem is cleared. If not you may have the inevitable convegence IC problem and the IC needs to be replaced. Let me know if that is the case and I will give you the procedure.
The image is distorted. Both the top and bottom
You have bad convergence ICs. There are two of these and replace them using the same stock number. You will have to inspect and measure resistors and replace as needed. Please see TVRepairKits.com. They may have a repair kit for you!
When I turn on my big screen, I see the input
This sounds like a convergence problem.
In the customer menu with the Mitsubishi remote select convergence and then advanced. You should see a grid of lines yellow in color.
If red or blue lines appear and are skewed and out of place you have found your problem.
I have step by step start to finish instructions for this type of repair in MOST OF THESE MODELS.
Let me know if it looks anything at all like the attached photos.
SD TECH
Found the leaking fluid problem that has apparently killed my set
Well, give this a shot. That fluid is ethylene-glycol which is water soluable. Pull the board with the fluid stain on it and wash it with water and dry thoroughly with a hair dryer. This works 90% of the time. Then put some kinda plastic sheet up by the leak to prevent it from leaking on the board again.
Mitsubishi WD-62327
The error codes are all different for the various models. But your WD62327 is the VK26 chassis DLP heres the error codes and the meaning for your model. Let me know if you need more help.
12 No Error detected, check Power Supply
32 Lamp Cover is open
33 Air Filter Cover is open
34 Lamp abnormality
36 Light Engine (DMD or LAMP Fan stopped)
37 Exhaust or Lamp Ballast Fan stopped
38 Lamp temperature high
39 DMD temperature high
41 Short is detected
44 DVI cable between FMT & Engine disconnected.
